698734 Views 550 Replies 172 Participants Last post by  Blasirl
10
2011-2016 Cruze 1.4L PCV Valve Cover/Intake Manifold Issues
Video:
I made a video to help better explain how this whole PCV system works to supplement this article.
Overview
I find myself having to explain this issue to someone almost daily, so in the interest of brevity, I'm creating a thread specifically for people to reference quickly if they have an issue.
The Cruze 1.4L Turbo engine has a terrible PCV check valve design that afflicts 100% of cars I have come across. It's not a matter of if, but when, it will fail. There are three primary components to this system that frequently fail: the PCV regulator diaphragm (some people call it a check valve) on the valve cover, the check valve in the intake manifold, and the corrugated hose going from the intake manifold to the turbo. We will focus on the first two, which are the most likely failures.
Symptoms
Depending on how long you've had this issue, your vehicle may throw a check engine light with any or all of the following codes (DTCs):
P0171
P0106
P1101
P0507
P0299
P2096
Note: lack of check engine light does not mean everything is operating correctly!
Your vehicle may also exhibit any or all of the following symptoms:
  • Elevated oil consumption
  • Smoke blowing through the tail pipe
  • A hissing sound in the engine bay
  • A rough/stumbling idle
  • Loss of power
  • Reduced fuel economy
Diagnosis
Valve Cover
With the engine running, inspect the vent on the PCV regulator diaphragm. The PCV regulator diaphragm has a round non-removable cap on the driver side of the valve cover. Remove the cosmetic cover off of the valve cover:
Underneath, you'll find the cap that covers the PCV regulator diaphragm. If this has failed, the engine will be sucking in air from here, and creating a hissing sound. Place your finger over this hole to cover it. If the engine RPMs change or the hissing stops, the valve cover needs to be replaced.
DON'T STOP THERE! Failure of the valve cover PCV regulator diaphragm may only be a symptom of a greater problem: the PCV check valve in the intake manifold. If the intake manifold PCV check valve has failed and you only replace the valve cover, you will find yourself replacing valve covers every few months not knowing why.
Intake Manifold PCV Check Valve
With the engine off, locate the corrugated hose coming out of the top of the PCV check valve:
With tightly gripped pliers, remove the clip holding the hose off by pulling it out:
Pull the corrugated hose off from the base, taking care not to pull from the hose itself as it may crack or tear. Using a flashlight, look inside the hole. If you are facing the engine bay from the front, there should be an orange/pink/peach nipple/valve on the "back" of that hole that looks like this:
If you don't see that check valve, use q-tips and rubbing alcohol to clean that area and check again. If you still don't see it, this must be addressed.
There's one final part that needs to be checked:
PCV Hose/Valve
In the last section, you need to remove a hose from the intake manifold. That hose has another check valve at the other end of it; at the turbo inlet. To verify its functionality, blow into the hose; it should blow freely. Suck air back through the hose; it should completely block airflow. If it doesn't do either of these, the whole thing needs to be replaced. Those hose also has a tendency to become brittle and crack, at which point it will also need replacing. Be sure to check this hose everywhere if you suspect it is leaking or are hearing a hissing sound in the engine bay.
Repair Solutions
Both of the above components are covered under your powertrain warranty. If your car is still under powertrain warranty, bring your car to the dealer and tell your dealer you are experiencing oil consumption of one quart per 1,000 miles and to reference GM Bulletin PIP5197C.
If the PCV regulator diaphragm on the valve cover has failed, replacement is required and will cost ~$60. Refer to this tutorial for replacing the valve cover. How-To: Replace the Valve/Camshaft Cover (1.4L Turbo)
If the check valve on the intake manifold is missing, you have three options:
1. You can replace the intake manifold with a new one. As of late early 2018, GM is phasing out the intake manifold that ships with all accessories and is selling a bare intake manifold. I don't yet have the part number for that.
2. Dorman has begun releasing an option. However, this option has the same check valve design as the GM manifold, meaning it will be prone to failure and boost leaks, and is not serviceable. The part number is 615-380, but availability is currently limited.
3. You can install one of my Intake Manifold PCV check valve fix kits for as little as $75, which is much cheaper than the Dorman intake (after shipping) while providing you a more robust, leak-free, and durable check valve. My external check valve design allows for easy (doesn't require removal of the intake manifold) servicing and cleaning, and inexpensive replacement. Details are in this thread: GM 1.4L Turbo Intake Manifold PCV Valve Fix Kits
A tutorial for removing the intake manifold is located here: How-To: Remove 2011-2016 Cruze 1.4L Intake Manifold
If the check valve at the turbo inlet has malfunctioned or the hose is cracked, you will need to replace it: ACDelco 25193343 PCV Pipe with Valve
Resources
To learn more about this engine's PCV system, refer to the following thread: 2011-2016 Cruze Limited 1.4L PCV System Explained
  • Helpful
Reactions: 5
241 - 260 of 551 Posts
Thank you Thebigzeus, that was it. Pulled the intercooler bypass valve and sure enough that was where the othere side of the hose goes. Found one on Amazon, will irder and replace it, then recheck the codes after.
Thanks again, you rock!
Cruze 1.8L 2012
Does anyone know if the Cruze 1.8L has the same orange ball/nipple on the intake manifold? I took the pipe out but there is no sign that there was something there it looks very plain and I cannot see any holes that suggest me that it is missing.
Nope. Vacuum on the 1.8 comes from only one source; no need for a check valve in the intake.
There is a similar design in the valve cover; it will make weird noises and run poorly when it's gone bad, but it's much, much less common than the 1.4T.
Thank you very much! What if after the PCV replacement on my 1.8L I still see a lot of oil consumption, oil on the intake manifold? Perhaps it was bad installed?
Hi I recently bought your #2 kit two days ago i installed it and didn't fix the problem. What do you suggest to do next iv already replaced the valve cover.
Going to need more information on what your problem is exactly.
Had the high pitched squeal and the lean code 171
When i took the intake manifold off the nipple was missing
That's a shame, knowing what they do you'd think they would change the design to make it better or at least incorporate a changeable PCV valve!
Should be a recall if everyone is having problems
Welcome Aboard!(y)
I didn't know that I had to into myself. I have a profile & have been posting for years. I had a 2014 2LT that had this repair done under warranty. My new 2015 Cruze 2LT is almost out of the 5 year power train warranty so I was wondering if this problem is covered beyond 5 years as it seems to happen a lot.
Turns out the intake did need the repair which i did put the V2 Kit in but did not take the squealing away turns out the front engine seal was bad making the noise i replaced it for $17.00 @ Advance part # TCS46113 wasn't leaking oil but did have a vacuum leak. Hopes this helps because i know a lot of these 1.4 have this problem
Unless you are also James1968, then no, you do not.:)
My daughter (2012 Silver 1LT) got the dreaded P0171 and her PCV system crapped out on a road trip from Norfolk, VA to Oklahoma City via Phoenix. The service department at Jim Keras Chevrolet in Memphis had the parts and are working to get her back on the road quickly. Kudos.
I shoulda done this mod for her this last month. I won't see the car again for two years.
It is not to my knowledge.
No. and it's about $500 to fix at the dealership. the Xtremerevolution fix is ~$100 and it's permanent. https://www.cruzetalk.com/threads/gm-1-4l-turbo-intake-manifold-pcv-valve-fix-kits.189402/
Found this from Dorman. I don't know if it was previously posted. Check it out.
I don't see it in the thread but could a boost/vaccum leak cause a p0033.
Yeah they posted about that. Unfortunately it doesn't resolve the following major issues:
1. The check valve deteriorates over time. It may not disappear but it will not perform the same.
2. The check valve may still get stuck due to oil and PCV deposits like many have found around theirs.
3. The check valve will fail to seal properly like many have found with theirs, due to deposits mentioned above.
4. The check valve is not serviceable.
The OE check valve fails and disappears due to a deterioration of the "rubber" it's made of. Placing a retaining pin behind it doesn't solve that root cause; it just prolongs its use and gives a false sense of security that the check valve is working simply because it's present, while the issues I mentioned will still cause a low crankcase vacuum condition that most people don't have the tools to test for. This will make diagnosing external leaks, elevated oil consumption, and poor PCV system performance even more difficult as even a service tech can no longer reference GM's service manual to diagnose the vehicle and must instead fully understand the inherent flaws in this design and how the whole system works.
My V3 PCV fix kits (Lite, Pro, and Race Edition), due to release over the next few months, address all of these issues in one way or another. V3 lite will be priced very aggressively, below even the current V2 fix kit, making it a superior fix with an easily serviceable with the best serviceability of all of my fix kits. I had a custom mold made for a fitting that will allow better factory integration, faster install, and greater system reliability overall in addition to easy catch can integration (Race Edition). I'll be announcing the arrival of the V3 fix kits as soon as each version is available. Expect V3 Lite to be available in about a month, as it is currently in beta testing.
Sent from my BlackBerry Key2 using Tapatalk
are we talking 23psi+ conditions? With my GTX250, I constantly see 25psi and would be interested in something like the race kit.
