697228 Views 550 Replies 172 Participants Last post by  Blasirl
10
2011-2016 Cruze 1.4L PCV Valve Cover/Intake Manifold Issues
Video:
I made a video to help better explain how this whole PCV system works to supplement this article.
Overview
I find myself having to explain this issue to someone almost daily, so in the interest of brevity, I'm creating a thread specifically for people to reference quickly if they have an issue.
The Cruze 1.4L Turbo engine has a terrible PCV check valve design that afflicts 100% of cars I have come across. It's not a matter of if, but when, it will fail. There are three primary components to this system that frequently fail: the PCV regulator diaphragm (some people call it a check valve) on the valve cover, the check valve in the intake manifold, and the corrugated hose going from the intake manifold to the turbo. We will focus on the first two, which are the most likely failures.
Symptoms
Depending on how long you've had this issue, your vehicle may throw a check engine light with any or all of the following codes (DTCs):
P0171
P0106
P1101
P0507
P0299
P2096
Note: lack of check engine light does not mean everything is operating correctly!
Your vehicle may also exhibit any or all of the following symptoms:
  • Elevated oil consumption
  • Smoke blowing through the tail pipe
  • A hissing sound in the engine bay
  • A rough/stumbling idle
  • Loss of power
  • Reduced fuel economy
Diagnosis
Valve Cover
With the engine running, inspect the vent on the PCV regulator diaphragm. The PCV regulator diaphragm has a round non-removable cap on the driver side of the valve cover. Remove the cosmetic cover off of the valve cover:
Underneath, you'll find the cap that covers the PCV regulator diaphragm. If this has failed, the engine will be sucking in air from here, and creating a hissing sound. Place your finger over this hole to cover it. If the engine RPMs change or the hissing stops, the valve cover needs to be replaced.
DON'T STOP THERE! Failure of the valve cover PCV regulator diaphragm may only be a symptom of a greater problem: the PCV check valve in the intake manifold. If the intake manifold PCV check valve has failed and you only replace the valve cover, you will find yourself replacing valve covers every few months not knowing why.
Intake Manifold PCV Check Valve
With the engine off, locate the corrugated hose coming out of the top of the PCV check valve:
With tightly gripped pliers, remove the clip holding the hose off by pulling it out:
Pull the corrugated hose off from the base, taking care not to pull from the hose itself as it may crack or tear. Using a flashlight, look inside the hole. If you are facing the engine bay from the front, there should be an orange/pink/peach nipple/valve on the "back" of that hole that looks like this:
If you don't see that check valve, use q-tips and rubbing alcohol to clean that area and check again. If you still don't see it, this must be addressed.
There's one final part that needs to be checked:
PCV Hose/Valve
In the last section, you need to remove a hose from the intake manifold. That hose has another check valve at the other end of it; at the turbo inlet. To verify its functionality, blow into the hose; it should blow freely. Suck air back through the hose; it should completely block airflow. If it doesn't do either of these, the whole thing needs to be replaced. Those hose also has a tendency to become brittle and crack, at which point it will also need replacing. Be sure to check this hose everywhere if you suspect it is leaking or are hearing a hissing sound in the engine bay.
Repair Solutions
Both of the above components are covered under your powertrain warranty. If your car is still under powertrain warranty, bring your car to the dealer and tell your dealer you are experiencing oil consumption of one quart per 1,000 miles and to reference GM Bulletin PIP5197C.
If the PCV regulator diaphragm on the valve cover has failed, replacement is required and will cost ~$60. Refer to this tutorial for replacing the valve cover. How-To: Replace the Valve/Camshaft Cover (1.4L Turbo)
If the check valve on the intake manifold is missing, you have three options:
1. You can replace the intake manifold with a new one. As of late early 2018, GM is phasing out the intake manifold that ships with all accessories and is selling a bare intake manifold. I don't yet have the part number for that.
2. Dorman has begun releasing an option. However, this option has the same check valve design as the GM manifold, meaning it will be prone to failure and boost leaks, and is not serviceable. The part number is 615-380, but availability is currently limited.
3. You can install one of my Intake Manifold PCV check valve fix kits for as little as $75, which is much cheaper than the Dorman intake (after shipping) while providing you a more robust, leak-free, and durable check valve. My external check valve design allows for easy (doesn't require removal of the intake manifold) servicing and cleaning, and inexpensive replacement. Details are in this thread: GM 1.4L Turbo Intake Manifold PCV Valve Fix Kits
A tutorial for removing the intake manifold is located here: How-To: Remove 2011-2016 Cruze 1.4L Intake Manifold
If the check valve at the turbo inlet has malfunctioned or the hose is cracked, you will need to replace it: ACDelco 25193343 PCV Pipe with Valve
Resources
To learn more about this engine's PCV system, refer to the following thread: 2011-2016 Cruze Limited 1.4L PCV System Explained
  • Helpful
Reactions: 5
441 - 460 of 551 Posts
I'm not asking about the check valve in the intake manifold. I'm asking about the PCV diaphragm in the valve cover.
Sorry, I did not see that you were asking about the regulator.
No apology needed (y)
I have a 2015 Cruze factory intake with a bad PCV check valve if anyone needs a factory core to perform the external PCV fix upon. I will ship to you for roughly the cost of shipping only. Email at [email protected] or text 704.9O5.423O.
I will package and check with USPS for exact cost for a committed buyer.
EDIT: Now listed in Parts For Sale w/Pictures:
You would probably be better off creating a For Sale thread here:
Thanks Xtreme for the detailed write up and videos.
I have the 1.8L version, so no turbo. Is it still the same concept? Check to see if the PCV regulator diaphragm is suctioning air while engine is running? If it is suctioning air, does the 1.8L have a pcv valve to check since there's no turbo? Losing a bit of oil somewhere but haven't found any leaks anywhere and engine idle + performance is still excellent.
To get his attention, you need to use the "Reply" function or use the tag function like this: @Shawn855
Sorry for double post. Following the great suggestion to get @XtremeRevolution attention haha
Yes the regulator diaphragm should not be sucking in air. Yes it still has one, but I think it's only the valve cover.
Sent from my BlackBerry Key2 using Tapatalk
I had a weird issue with my cruze recently. To give a run down, I had the usual codes pop up and found out about the cover and replaced it. Reset codes then month later codes came back... found out about the v3 cruzekit and bought and installed then reset codes and things had been great until 2 months later when Englishtown came on but now instead of a bunch of codes i was down to the 299 underboost code. Checked oil and it was low very low little to none. Replaced that and engine light went off. Was fine after a week but then noticed some smoke in the light at night and looked inside and I have oil around my filler cap. No check engine light. Was wondering what this could be? I am at 121k miles now and this might sound random but my coolant level has always stayed low and someone suggested my problem could be the oil cooler. Would bad seals on oil cooler cause a positive pressure on the crank case? And why no codes? I've checked the filler cap and that doesn't seem to be the problem even replaced it.
Oil cooler maybe, take pics and create a new thread.
the oil cooler is a heat exchanger between coolant and oil...how should it cause pressure in the crank case ?
Want some clarification. What if the diaphragm port is not sucking air (or blowing air for that matter)? I have a 13 sonic with the same 1.4t engine, but similar fault codes and rough idles. Couldn't check the valve inside the manifold, but isn't the rough idle caused by the vacuum leak from the torn diaphragm? The check valve issue is the root cause of the torn diaphragm, but can it cause rough idles by itself?
What are the usual codes?
... when Englishtown came on???
Potential causes of a P0299 turbo underboost code include:
Intake (induction) air restriction or leak
Failed or damaged turbocharger (sticking, binding, etc.)
Faulty boost/charge pressure sensor
Read more at: P0299 Turbocharger/Supercharger A Underboost Condition
You may not have corrected all of the issues when you installed the kit. You need to clean the engine off and start clean and look for leaks. You also need to make or buy a boost pressure tester.
When you installed the kit, you should have first tested the intake manifold to see if the PCV vacuum diaphragm was blown, necessitating a new valve cover if it was - could be covered under warranty - even though you replaced it earlier, then you should have checked for a blown front crank seal.
As for the coolant level, there is a myriad of known and easily fixable issues with the cooling system. Check the thermostat housing, water outlet, the water outlet to surge tank hose, the surge tank and cap. After you have added Dexcool, make sure you bleed the system correctly or you will have more issues.
I did not understand your question, but the post you are referring to is about the 1.8 not the 1.4.
You need to check the valve, it is not that difficult and is the same procedure as the Cruze to do it.
My dear opel 1.4 T LUJ have the same issue, first it started to leak at bleeder hose water outlet, fixed that by having a machined adaptor, after that i replaced the timing chain and everything that is there to be replaced because it was already 10 years old and the water pump was going bad aswell. The leak stopped, one week later the valve cover membrane broke, unsealed the cap, put a cheaper membrane that is not original and not even the same size as the original one, glued the cap back, now it spills oil trhough the vent cap since the membrane is not sitting on properly. I bought myself a new very cheap engine cover(the quality of it is worse than the original one but the original one costs like 3-4 times more) and i will have to do modify the pcv system aswell because the rubber tittie is not present anymore in the intake.
Mileage: 87 000 miles but i doubt the valve cover is the original one
I took off the intake manifold, the intake is missing the nipple and both the intake manifold and the valve cover are original from 2011 when the car was built. I will temper with the PCV system and install a new valve cover. I was expecting more carbon built up but the intake manifold catch can system was full of oil so i had to drain it out
293439
293438
You can plug up that hole where the check valve used to be and order the v3.3 pcv fix kit. That can be installed without manifold removal. Car will run fine till it arrives.
Nah, already taken off the intake manifold and plugged the hole. I won't order the kit because it's too much hassle to order it in romania and the cost is unjustified since i can fix it with 10-20$ bucks and i really wanted to take off the intake to give her a good clean. The catch can area of the intake was full of oil, you could hear it splashing all over the place. I was thinking of this system before finding out the cruzetalk since the russians complained a lot on forums aswell.
How are you going to fix it then? You can't just plug the hole and go about your day.
I've shipped about 20 of my kits between Romania and Moldova. I'm Romanian as well, was born in Jibou.
You can't just plug up the hole, as noted. You'll lose vacuum on the crankcase which will cause higher oil consumption, reduced piston ring seal, reduced efficiency, and reduced power. Over time, this will eventually damage the catalytic converter as well, and result in more external leaks. The right way to fix it is to re-route the check valve externally.
