Hi Guys, hi
@XtremeRevolution.
Great to see such a helpful community!
I recently got a lot of trouble with my Astra J 1.4 T A14NET. After some research in german boards I came across the PCV Fix Kits, now I need some help with diagnostics.
What happened:
Phase 1:
Under heavy load, the display showed "Fahrzeug demnächst warten".
The error log had the entry '
P0299'.
I ignored this error for some time.
Phase 2:
After a longer trip, Oil leaked from the valve cover gasket and the camshaft adjuster gasket, apparently under high pressure. A repair shop fixed this by replacing the to gaskets, but unfortunately I forgot to tell them about the error P0299 and they didn't check the error log.
Phase 3:
On another trip to Italy, the check engine lamp came on. I again checked the error log, this time the entry was
P0171 - System too lean, bank 1
P0106 -
Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor - range/performance problem
P1101 - Mass air flow (MAF) sensor - range/performance problem
I also noticed that the engine was sucking a lot of air through the small hole at the diaphragm inside the valve cover.
The engine ran unsteadily at idle, but quietly under load.
When I covered the hole inside the valve cover, the engine run more smoothly, but after like 15 seconds, a lot of smoke came out of the exhaust.
I stopped covering the hole, the smoke was gone, and I decided to continue driving as it was late in the night and I was already in Italy.
Phase 4:
On my way back, I worried about the engine and tried covering the hole again, but only partly. I hoped I could reduce the amount of air sucked in, so the mix wouldn't be too lean. After a few seconds, the exhaust again blew out a huge amount of smoke, but this time it didn't stop for maybe 30 seconds, so I decided to stop the engine and get the car back home by a towing service.
Right now the car is at a repair shop, but I'd rather try to fix it on my own.
I removed the corrugated hose, and couldn't see the orange thing. But there was really a lot of oil inside, so maybe I should clean it first.
I'm sure the diaphragm in the valve cover is broken, I suspect also the valve inside the intake manifold.
How would you proceed to further diagnose the problem?
Is there any explanation for the huge amount of smoke though the exhaust when covering the hole in the valve cover?
Btw., I already ordered the PCV Fix Kit.
Thanks in advance for your help!
