1 - 9 of 9 Posts
My 2011 chevy cruze started jumping and sputtering on full acceleration or whenever it's goes above 15 psi. It started doing this a few weeks ago and thought it was the ignition coil. I changed the ignition coil and it was fine until about a week later when it started doing it again. On full acceleration the traction control and stability control will turn on sayings it's failing or something like that and the engine light will blink. As soon as I let off the accelerator it all goes away. I am tuned and have a down pipe and CAI. I would appreciate any help that you guys can offer thanks.
Sent from my SAMSUNG-SM-G930A using Tapatalk
This could be the first signs of a PCV valve failing.
I thought it might be that but it doesn't idle rough or anything. The only time it's rough is when I accelerate fast otherwise it's like there's nothing wrong with it.
I'm having the same issue with mine. Idles perfectly but giving it any sort of throttle produces hesitation, whether it's 10% throttle or 100% throttle. I've tried 3 different spark plugs gapped anywhere from .022 to .030 to no avail. I'm starting to wonder if my coil pack is bad. 2015 ECO 6MT with 11,000 miles FYI.
Since your car is still under warranty I would just take it into the dealer. As for the OP it pretty much sounds like what my car behaved like with spark blowout. You could also try cleaning off the MAT and MAF sensors as they can develop oil buildup.
1 - 9 of 9 Posts
