1 - 15 of 15 Posts
Ok just bought the car has 121k miles and 4 owners so what would a full time up consist of. Also keeps throwing p1101
You mean tune up?
Ya my bad tune up
Spark plugs, air filter, professional fuel system cleaning. I'd try cleaning or replacing you MAF sensor with the P1101 if that's the only code. Do you have any codes other than P1101? Also, the car is stock, correct?
Apparently maf was replaced two weeks ago
Is your MAF wiring harness ok? Do you actually have driveability issues or just a check engine light?
Like if I cover the intake hole it adjust and don't die
I'm a little confused. Cover the intake hole and don't die? A picture and a little more explanation would be nice.
Gotcha. What I was asking, is does the car drive ok? Or does it hesitate or surge? That's what I meant by driveability issues?
Discussion Starter #13
No drivability issues I just want the light of in case something does go wrong on it
I'm the same way. @Blasirl any advice for P1101 with no other codes?
Chevy Cruze P1101 Causes
Engine Wiring– A good place to start is to do an inspection of the area around where the mass airflow sensor plugs into the intake. Make sure that the wiring doesn’t look broken or disconnected. You’d be surprised, in the winter months a rodent can cause a lot of damage to a an engine in one night.
Air Filter– Pull your air filter and see if something has gotten in there. If it has, remove the debris. Or if the filter looks very dirty go ahead and replace it. If enough air is not getting into the engine the mass airflow sensor is not going to get a proper reading, and P1101 will likely be thrown.
289529
If neither the engine wiring or the air filter seems to be a problem, then it’s going to be time to pull the mass airflow sensor and see if it is dirty. A word of caution, these sensors can be incredibly sensitive to the oil’s on skin so make sure to use caution and not touch the sensor element itself.
Leaking Intake– If the intake seal on the Chevy Cruze has been damaged, there’ll be a vacuum leak. A vacuum leak means that air will be getting in to the intake not through the throttle. This is going to dramatically alter the reading at the mass airflow sensor gets and will trigger P1101.
A mechanic would be able to do something called a smoke test, which would let them visually see where the intake is leaking from.
If you would like to try to find the vacuum leak yourself go ahead and perform a visual inspection and make sure that you don’t have a disconnected or broken vacuum hose. If it looks ok, than carb and choke cleaner can help. Here’s a good video on vacuum leak diagnosis.
MAF Sensor May be Bad– at this point the only cost that we should have incurred is the cost of a can of carb and choke cleaner. If everything checked out, and there were no intake leeks, than it’s time to evaluate whether the MAF sensor is bad.
Here’s another YouTube video. This one goes over how to test a MAF sensor with a multi-meter. It’s relatively easy to do and multi meters are cheap.
Will the P1101 code make the Cruze stop running?
The P1101 code typically will not be enough to make the engine not run. A bad mass air flow sensor is enough to make the engine:
  • Idle poorly
  • Consume more fuel
  • Lose power
If left unchecked, a bad MAF sensor can lead to other engine problems.
Read more at Chevy Cruze P1101 and P0171 Trouble Codes | Drivetrain Resource
1 - 15 of 15 Posts
