Can not remove key, Can't get the transmission out of park, No rear brake lights, No rear parking lights, Cannot open trunk with remote. Rear window brake light works, Turn signals work, Reverse lights work. ???
I'd check the fuses on the fuse block in the dashboard. If that's not it, then I'd check the wiring going to the back. Hopefully, this isn't a bad BCM ($$).
