Are there any codes or DiC messages? Which engine? Check your PCV setup.
1. Year, trim level, and transmission.
2. Miles on the car!!!
3. Check engine light, airbag, or other warning light on or "Service [insert system here]" message showing? Has somebody told you the code if the check engine light is on?
4. Approximate location of the issue.
5. As detailed a description of the problem as you can give. Something like "My 2012 Cruze Eco manual transmission with 50k miles on it is making a grinding noise from around the brake pedal at 12 mph every time I start the car, and doesn't do it again until I start the car again" is enough to let us get started. (Hint: I described the ABS self-check, and that check is normal for every Cruze on startup)
6. Country! Your warranty and repair options might be different in other countries than here in the United States or Canada.
7. (as needed): Left-hand drive or right-hand drive? If your car is right-hand drive, that's nice to know since a lot of us on this board have little experience with RHD cars.
(Stolen from Sciphi)
