2011 Cruze LS 6 Speed Intermittently Starting
434 2
Hello,
Some background, I've been having some other power related issues such as the car shutting off when idling with the ac on but only with the specific scenario and the performance of the car didn't seem to suffer. Then I posted about a noise and that has now been seemingly diagnosed as an exhaust leak and i am working on getting that fixed. However I'm not having issues with the car not wanting to start.
Symptoms:
  • Doesn't want to start. Sometimes the lights on the dash will come on, door will chime, radio will come on. Most recently everything is dead and car was jumped and everything came on.
  • Extremely slow to accelerate, have to turn off a/c.
  • Decreased gas mileage. Used to be 28.5-28.7, now is 25.5ish.
  • Service stabilitrack comes on while the radio and leds on the radio simultaneously turn off. This is brief, 20-30 seconds and it turns back on.
  • Exhaust leak, whining noise.
  • Engine codes: P0014, P0171, P0420
  • A/C causes car to shut off while idling. Whether in park or in neutral.
The battery is a month or two old, no reason for it to be the battery. That was the original thought. Oklahoma heat + battery=disaster but apparently not.
Any insight? I'm working on getting these things repaired but like many, life is difficult and I don't have a bunch of money to throw at this all at once. So I need some guidance. Any and all help is appreciated and I do have someone who will be doing the work for me.
Thank you.
Gadget Sports equipment Gas Electronic device Audio equipment
Motor vehicle Gadget Gauge Measuring instrument Gas
Communication Device Gadget Plant Audio equipment Measuring instrument
Whining noise (has gotten worse, now full blown typical exhaust leak noise)
1 - 3 of 3 Posts
Well Peach,
I would say you seem to have two issues.
Well, unfortunately a new battery doesn't mean what it used to. I would have BOTH the alternator and battery load tested. AutoZone will do this for free.
Along those same lines. If you are running the stock negative battery cable, that needs to be replaced. It is a known issue that is extremely hard to diagnose.
The other problem, that I'm almost sure is causing half your codes, is the exhaust issue. If you can find the leak (if it is a leak), JB Weld (highHeat) might be able to patch it.
FWIW dude, you / we need to find out what's the issue first. Then we can help you fix it as inexpensively as possible. (y)
1 - 3 of 3 Posts
