About a week ago on the way to work, pulling out of my driveway, my 2011 Cruze LT with 1.4L engine sputtered a bit, surged, then ran normal until about 5 blocks later when it just died.
There was a noticeable burning plastic or rubber smell at the time of death. When the tow truck driver arrived (an hour later!), he commented about the burning smell.
So far, I have the following data:
- Cranks, but won't start
- Codes thrown are: P0304, P0201, P0202, P0203, P0204
- F9 is blown. When replacing it with a new fuse, it blows again immediately when you key the ignition
- Resistance reading from F9 (non-battery side) to ground is 5 ohms
- Removed electrical connectors from all 4 fuel injectors and measured resistance across each injector- all read about 12 ohms
- Inspected for wires/connectors that look like they got hot, but haven't been able to find anything obvious yet
I'd like to try (another) new fuse F9 and key the ignition with the connector of Fuel Injector #4 pulled off, but I'm not exactly sure what the cylinder order is.
Standing in front of the car looking at the motor, is it 1,2,3,4 from left to right?
Or maybe I'm chasing rabbits since all 4 fuel injectors ohm out at 12 ohms?
Any help or ideas would be greatly appreciated!
