Will give that a shot this weekend. Thanks.try disconnecting the battery for 10 minutes...
Everything else is there, just the speedometer is gone. The regular analog one works, of course, but this just vanished and I see nowhere to re-activate it.Are any of the trip odometer/fuel screens present or have those also disappeared?
So, clearly you know how to scroll between screen by twisting the little ring on the end. You're saying that once you press the menu button, that you can't scroll at all?all I can see is the tire pressure, oil life, battery power.
Arsig320 indicates that he can scroll. I'm not sure about OP. If they can scroll in the other tab, but not in this one, then that suggests one of the computers (DIC?) has gone out to lunch. Disconnecting the battery seems like a good fix if shutting down the car and opening the driver's door doesn't do it. (Of course, check for scrolling after that.)That appears to be the blank screen in the vehicle information display rotation. If you're unable to scroll away from it then I'd suspect the control stalk has failed as it's the only mechanical part of the system.
Yes, I can scroll just fine, all other information except the speedometer works just fine. But when you drive, you get nothing but a blank screen instead of the normal speed.Arsig320 indicates that he can scroll. I'm not sure about OP. If they can scroll in the other tab, but not in this one, then that suggests one of the computers (DIC?) has gone out to lunch. Disconnecting the battery seems like a good fix if shutting down the car and opening the driver's door doesn't do it. (Of course, check for scrolling after that.)
Just to be clear, the screen pictured is NORMAL and can be selected. It's the inability to select other screens that's abnormal.
Everything else is there, just the speedometer is gone.Are any of the trip odometer/fuel screens present or have those also disappeared?
Nope, it works fine, can get to everything, the digital readout for the speedometer is gone, everything else works.Are you able to use the menu button to switch between the car info screens and the trip/odometer screens? I'm wondering if the menu button has failed.
