Hello everyone,
It has been a long time since I came on here to post. My Cruze is now at 125,000 miles, been a good car so far, feel like we really connect and I know her well.
I've been taking good care of her, general as well as preventive maintenance. At about 100k I successfully replaced the timing belt and water pump and she's been running strong. Lately however things have not been all that great, I am having an issue with the coolant system running cold at highway speeds although I recently replaced the thermostat due to a P0128 and now shes leaking trans fluid and engine oil
The coolant problem I am pretty sure is due to the fact I did not flush and replace the coolant properly, will do that sometime this week. My biggest concern is the leaking fluids.
I opened the hood today to check my oil and noticed I am half empty, its all over the bottom of the pan (will need to top off). Then I noticed wetness all over the driver side skid plate area. After further inspection and collecting a small sample, I realized it was pink in color and oily, I figured its transmission oil. Checking from top to bottom I tried to locate where it might be coming from, its hard to tell exactly but the top most part where its all oily is the bottom most trans coolant line.
Any thoughts?
Any thoughts?
