Recently discovered some issues just seeing if anyone has advice or went through same things.... #1 noticed a misfire and arc coming off last spark plug on the right side(looking down at motor). #2 while changing out plugs and coil pack i noticed the same plug that was misfiring had oil on top of it an when i pulled it out oil was dripping off the bottom..... With that being said my question is, is the oil coming from the build up from not being burnt off while misfiring? OR is the misfire being being cause by the oil coming from else where?
