Hi.
Adding details per sticky thread. 2012 1.8 LS manual. About 105k.
I recently replaced the thermostat and cover, I think the parts are called. I now have a drip of coolant below the pipe that is below the thermostat. I'll attach a picture at the bottom. I took the thermostat off and double checked my seal and it appears okay. I did have to loosen the whole housing off the block by about a quarter inch to get the thermostat cover off. My suspicion is that the seal between the housing and the black didn't seat correctly when I tightened it back down but there's no way to check that without removing everything. I'm wondering if perhaps I made a mistake by not buying the whole housing in metal which is only about $10 more than the part I did buy. Anybody want to confirm the suspicion or make another suggestion? Thank you
