1 - 3 of 3 Posts
Its started a couple of months ago. The best way to describe the sound is it sounds like the Jetson's car while accelerating through first gear and into second. I cannot find anywhere that someone is having the same problem. No other gears and at no other time does it make this sound. It is very embarrassing at ever stoplight or stop sign. Any input would be greatly appreciated!! It is a 6 speed manual with about 68k miles.
Hopefully under five years old........the trans bearings are dying on the idler side.
1st is the worst because of torque multiplication.
This trans is not considered rebuildable.....no parts support.....it is replaced at no charge if you are in powertrain coverage.
Take your dealer mechanic for a ride to reproduce the sound.
Since the labor is mostly the trans, a wise operator would take this opportunity to replace the clutch....only about a additional hour plus parts.
1 - 3 of 3 Posts
