1 - 4 of 4 Posts
Hello Cruze family so I think I’m having a common electrical issue
My cooling fan only turns on when my A/C is on even the car has been running for
3 hours
Has new thermostat, fan relays , and temp sensors
Any ideas ?
I’m thinking it’s some type of electrical problem
You did not mention, but is your car overheating? Or, do you think the fan should be on just because you drove so long? If the car is not overheating, then the fan does not need to be on. The electrical fans do not always run. Since you have a 2012 model, you should be able to see the coolant temperature reading from the driver information center readouts. Fan does not start until coolant temperature is around 220+.
1 - 4 of 4 Posts
