At 172,000 miles my cruze is a huge headache. First, it was like pcv issue, manifold seal, and ignition coil pack..
Not even 6 months later, ignition coil pack blown yet again. Took it back in and they replaced it again, and I brought with me a brand new battery because when what I thought was a simple coil pack replacement additionally smelt electrical burning smell so just in case got new battery.
The newly replacement coil pack immediately burnt, and they told me that a belt is flinging some type of fluid (coolant possibly) which is causing electrical shorts. I towed the car straight to chevy and they told me that yes, coolant leak causing shortages not only to coil pack, but to ECM as well. They fixed the leak&coil pack and told me it was all good.
next day engine light again, so went to chevy immediately and they told me the ECM just wasn’t connected all the way.
ONE MONTH LATER, on way to pick up my baby my car went into this intense multiple seizure like event, which included :
Losing engine power/no throttle!!!!
Shut down
Electrical burning smell
Flashing dash warnings all over the **** place
Within mins, it was on a tow truck right back to chevy and chevy assured me the warranty from previous work, if what I’m describing is right then it’ll be covered……..
Told me my ECM is blown and all of a sudden Thad corrosion and that I would need a new one and wiring harness, BUT NOT COVERED BECAUSE THIS WAS NOT APPARENT ISSUE hence not covered! **** receipt from them initially even stated “ecm” when I had to pay hundreds of $$$$ and now “this will fix your problem once and for all though.” Yeah for $2,000!!!!! Straight thievery at its finest!!
nope, tow dang thing back home and now trying to see what I can do on my own!! I’m a single mother and being robbed by CHEVY one more time isn’t an OPTION!!
ANY HELP THAT ANYONE CAN GIVE ME! I would be greatly appreciative!!
I’ve plugged the three connectors back in on ECM that they just left lying about, it started hurting rough for sure, and current codes are:
P1682
P0700
Shut down
P1682
P0700
