1 - 20 of 34 Posts
So I've read through many of the threads for this topic and have not seen one that is 100% the same to my issue. I'm having issues after part change outs maintaining a temp range within spec. I am hitting Temps upwards of 230 at 75 mph but averages at 225 - 226. When I am traveling at 30 - 40 or stop at lights it is 207.
I had changed out the water distribution block last year on the driver side by the valve cover. It started doing what I've explained above so i dropped it off at a mechanic. He changed out the thermostat and lower radiator hose plus pressure test and found no additional leaks. The problem above continues.
Would bad sensors on the distribution block do this or even the one on the radiator?
2013 Cruze 1LT
Those temps sound fine to me, mine runs at 206-210, I am in Austin TX, but also tuned. I think that adjusts it. Stock goes up to 225 I believe. Did you use an AC Delco thermostat? Any check engine lights? At those temps your front fan should be wailing, full speed. I'd be willing to bed it's messed up and not going into full speed. Post #5 here: What temperature should the Cruze be running at?
Discussion Starter #3
They replaced it with MTO, im dropping it back off and they are going to be putting AC Delco in. I always pick AC Delco for replacement parts but I didn't have time to do this work. I've never even heard of MTO.
No check engine lights, no codes. I'm in Beaumont so heat is always an issue. The fans were not going into high unless I use the ac and even then they weren't going crazy. The majority of my issues are at highway speeds though so the air moving through the radiator shouldn't be the issue in my opinion. I figure at 75 mph, there should be a good amount flow through. I may be wrong though.
2013 Cruze 1LT
The MTO doesn't even open until 221 according to this https://www.carparts.com/details/Chevrolet/Cruze/Replacement/Thermostat_Housing/2015/LT/RC31960002.html?TID=gglpla&origin=pla&utm_source=google&utm_medium=pla&utm_campaign=8862027007&gclid=EAIaIQobChMI6bjZi5bX6QIVicDACh0OmwCgEAQYASABEgLPpvD_BwE&gclsrc=aw.ds
So that is likely your problem. It may however be the ECU controlling it to be this hot to help the engine with efficiency, hotter engine is more efficient and obviously heat and load isnt an issue at 70mph due to the wind. How are you monitoring the temp? Good info here as well: Normal coolant temp, thermostats, and AC off due to high...
Discussion Starter #5
That site shows the Dorman to open at 221 as well. I have been looking at the DIC for the temperatures. I tried to disconnect the battery to clear the EMC and have it relearn. Is there a different process to clear the computer?
The car use to run at 217 highest once it reached the temp to open the thermostat so running anything past 225 is abnormal after observing those temps for 110k miles. This issue mostly started after changing the water distribution part by the valve cover on the driver side. That houses the engine block temp sensor. Thats why I was mainly thinking it was a faulty sensor that came with the part.
The mechanic did say that the thermostat broke up into pieces when they were taking the original one off so that was a justified change. As far as the distribution block goes, it was cracked.
Would be nice if GM would stop bolting plastic to engines that fatigue after thermo cycles.
Discussion Starter #6
So, I changed out the cheap sensors on the radiator and water distribution block. Got in it to warm it up and I hear grinding/high pitch scratching coming from what appears to be the water pump.
Sensors and thermostat didn't fix it but that noise is relatively new. I will be doing the water pump next.
Discussion Starter #10
This morning I took a drive off of a cold start situation. I drove down the road at 75 mph and it went up to 240° before it dropped down to 226° where it stayed. Pulled up in the drive way and touched the thermostat and it was cold enough to keep my finger on it. Turned the car off and let it sit for 2 mins and touch the thermostat again and it was hot enough to touch for only a moment. Cranked the car back up and the temps dropped to what I'm use to seeing, 212° to 208°. Drove it to drop off at the shop, they have a three year warranty on parts and are swapping the thermostat. The grinding noise at the water pump only occurs at cold start. I drove around yesterday and it never went past 225° and averaged 212° - 208° once the cold start and heat soaking occurred.
I'm still feeling like the new thermostat was faulty but with the new noise from the water pump makes me feel as if there is more to this. I see how, from previous comments, how GM has extended the warranty on the water pump "leaking" but mine is not. Wonder if they will honor that in this state...
I will see where this goes, I need this car back on the road for my work car. My TBSS has a leaking rack and pinion and GM nor aftermarket makes a new one. A1 Cardone will rebuild it but I have to wait for this COVID19 crap to quit before they open their facilities to do the work. When it rains, it pours.
Discussion Starter #11
If anyone can answer this question. The dealer wants $154 to run diagnostics and will wave the fee if the water pump or anything additional is replace which was diagnosed. The shop i have it now will do the pump for $618.
Has anyone been denied replacement of a stock water pump replacement.. I'm not sure if it is leaking but it is making noise. I dont want to pay dealer prices if they come up with some way to get out of the warrenty and end up $154 in the hole.
The shop it is at now said that the thermostat is ffine. With what I've explained in the previous reply,, does that sound fine to the cruze gurus in here?
Tbh the water pump at the 154$ is a great price. But my Chevy dealer replaced it under warranty so with the recall it should be free honestly you need to find the recall information. Special coverage 14371 and 14232
Do the thermostat change you will find on this site. Never again worry about temps.
240 is high but not out of range. Not normal to see those temps tho. The thermostat starts to open at 221. High loads at low speeds/deceleration should open the thermostat and lower the temp... cruising/light peddle and the engine will get max temp for efficiency 221-230, but this is also influencing by the air temperature. If it's cold outside it will run hotter.
Wot pulls I could bring the temp down below 200 than right back up to 220s 10 mins later
I have a bnr tune now and the temp stays around 195.. fan kicks on low at 200. Only hear it on after it heat soaks or use the AC. You can buy a tune to reprogram when the thermostat opens and leave out the performance gain if you wish
Discussion Starter #17
Dropped it off at the dealers, they called back saying they will change the water pump free. After that, not much else there to cchange. I'll see where I stand afterwards.
I never had interests in putting performance parts on this car but its funny when things go wrong is when you start seeing everything out there. I'm not going big by no means with the TBSS being that vehicles purpose but what does a mail in tune go for on a cruze? I've seen trifecta, zzp and the one mentioned above. With no other bolt on what does one expect at the wheel? 20 hp?
Look up BNR. It's not a mail in tune, you're buying someone's expertise to optimize your car the way you want it. Engine and transmission. I believe they claim 55 hp 120 lb torque gain running 104 octane on stock setup. You request what you want changed when you order. They'll modify your stock logs and you flash it to the car.. it's easy.. then do some data logging with the device you get and send it back to them.. they'll tweak or fix anything out of the ordinary.
They have economy tunes also... I'm running a 20 psi boost tune right now, but if I stay out of the boost I'm getting killer mpg...better than stock. 14 automatic.. I live in hilly Tennessee so great mpg has been a struggle with the cruze drinking gas on the inclines lol...a tune fixed that.
You also get efi live
Discussion Starter #19
Got back from the dealer. They didn't run any test, just replace the pump. Hovered around 225 on the freeway but dropped when I gave it throttle from cruising speed. Going to drive it around town to see how it acts, may change out the thermostat to ac delco if it acts up. Still seems like that. Did bring it to a dealer way back for a recall to find that change the thermostat temp but never acted up till recent. Something is still a miss here. Got a new water pump out of the deal but did get the expected results.
2013 Cruze 1LT
To be completely honest, I think you're looking for a problem that doesn't really exist. What is your worry with a few degrees higher?
1 - 20 of 34 Posts
