Hey guys i need some help. My cruze is misfiring accelerating and pretty much misfires around 2000rpm. I checked my spark plugs to look for any corrosion or any problems with them and moved them around. The plugs are gapped at .35, I for some reason couldnt gap them lower but if advised will replace them so i can gap them correctly. It's also gotten colder and seems to be misfiring more often/ hesitating. I have done a lot of research and MY belief is that it is the ignition coil pack failing that is causing my issue but I'm searching for some advice before i go and spend $160 on a coil pack. If you can help me that would be great.
