1 - 3 of 3 Posts
Hey there folks.
I've been driving an old Chrysler LHS 2000 for the longest time, and finally purchased my deceased grandfather's 2012 Chevy Cruze from my folks because I felt it was time to get a car that wasn't over half my age. She's been doing just fine, but I've occasionally been getting a check engine light (it comes and goes, mostly isn't there). I hooked up an OBD-II tool and got back a P0597 code. There seems to be a lot of debate about whether or not this is the thermostat itself or just the sensor - it's been fixed from both. I've decided to try the cheaper alternative first: the sensor replacement.
Now my question is, where do I find this sucker? There seems to be some variation on part location between the 2011 and 2013 Cruze models, while I am right in the middle. Here's the car specs:
2012 Chevy Cruze 2LS
Engine: 1.8L L4 DOHC 16V FFV
Part: ACDelco 213-4688 Engine Coolant Temperature Sensor
I'd post some pictures but I'm a new member, so, let me know if you need any more information!
Hey there folks.
Welcome Aboard!:welcome:
2LS? I am not familiar with that. Is it a 2LT?
Look at some of these threads to see if you can find your answer:
Cruze Cabin Odors, Sources, and Resolution Summary
Antifreeze Smell Thread V.2
http://www.cruzetalk.com/forum/25-gen1-service-issues/5843-antifreeze-smell-thread.html
Also try searching for "Coolant Sensor" at the right.
I found it with the help of a member's PMs! Thermostat was right by the engine, and this little sucker was easily held in with a pin that I just needed to remove. Voila!
Also I think it's just an LS, not a 2LS!
1 - 3 of 3 Posts
