Update:
Got the code cleared yesterday and did some testing to make sure the dampers are opening and shutting (they are), then drove back home. The issue is only happening when going uphill at low RPM ranges. When temp begins to climb, if I downshift to raise engine speed it drops back down to a normal operating temp. Assumption is that a bubble trapped in the radiator is being compressed by the increased speed of the pump in that condition.
Did a full drain, flush, refill, and bleed of the coolant system after I got home today. Hoping that the issue was a bubble in the coolant system, but if the problem persists, then I’m assuming my next step is a water pump and/or the thermostat (though I think the thermostat is good).
