1 - 7 of 7 Posts
Hi all. My daughers Cruze is having a little problem. I noticed the idle is rough about every 4 seconds. Runs fine for about 3 seconds, then a hear a noise like air escaping and at the same time the engine is about to die or run rough. The noise is coming from the valve cover on the top left side. I think there is a pvc valve built into this cover. I do have a video of the problem on youtube labled:"2012 Chevy Cruze engine noise".
There is no check engine light. Whats ya think?
John
it is likely a failed PCV which has led to a cracked valve cover.
There are a couple threads related to this issue.
That is a strange one.
Unplug the purge valve (round canister) on the back of the intake manifold and see if it still does it.
1 - 7 of 7 Posts
