The vehicle in question is:
2012 Cruze LT w/ Manual Transmission
149,000 miles (no warranty)
Moderate to Aggressive acceleration
Used for Uber 45,000mi - 149,000mi
The last transmission oil change was at 125,000mi. I was planning to change it out at 150,000 but it looks like I'll be doing it early as it might be the culprit. If that doesn't make a difference, I'll be inquiring more on what parts to change out during a transmission drop.
While the clutch is engaged and driving normal, when the gas pedal is depressed to accelerate, the RPM's jump up as if the clutch is not engaged. This happens in 3rd, 4th, and 5th gears. 1st, 2nd, and 6th are functioning normally for now.
This just started to happen today out of the blue. 3rd, 4th, and 5th are still usable, but only with a light touch of the accelerator pedal.
I'm going to be changing the fluid now and I'll update if whether or not that helped with the issues posted above.
