Your car is running lean.
Bring it to the dealer (any dealer), sorry for the bad luck but it's probably a simple fix.
You still had 1.5 to 2.5 gallons left in your tank. Low fuel didn't trigger the CEL. However, if you didn't get the gas cap on tight (mine actually says to turn two clicks) you can get a CEL for fuel system pressure issues. I've run my tank to fumes twice to get a good feel about the distance to empty and needle movement at low fuel levels (tells me when to panic about running out of gas) and not had a CEL.Hi. Everyone:
I do need your advices. This evening I went out and drove the car in a short distance, around 3 miles. The checking engine light went off in the middle of the driving. Before the driving, I closed again the fuel cap and heard one click. (when I added the gas, I always make sure that I turned the cap in and hear one click). I also pushed the oil dip stick firmly down. Even though the stick was firm in the first place.
The things I also have done before then the checking engine light was on:
1. I added gas two days ago. This time the tank was almost empty. I ususlly have the habit to add gas when there are 1/3 of the fule left. But this time I almost emptied the tank. This time I added 10.5g gas. The volume of the fuel tank is 12.5g.
2. After I refilled the gas, I changed the oil and filter two days before the checking engine light went on. I drained the old oil first. Then I took out the oil filter. After that the new filter, then I put back the drain plug, finally I added 4.2 qt. 5w-30 Mobile1 synthetic oil.
My questions are:
1. Since the checking engine light is off. Do I still need to take the car to the dealer?
2. Adding gas when the fuel tank is almost empty triggle the checking engine light?
3. Order of changing oil filter after drain the oil triggles the checking engine light? (Because I watched a Fram video, the guy in the video said you should always take out the filter, than drain the old oil)
Thanks for your help.
Dan
Hi. Every one.
Please help.
2012 eco mt. bought on 29Nov2012. 1,500 miles. changed oil two days ago. Filter+Mobil 1 5w-30 synthetic. Today I have check engine light on.:angry: The code is P0171.
What the possible cause? If I take the car to the dealer, could I take it to the dealer near my home, not the one I bought the car from? Also while I leave my car there, could I get a loan car?
Thanks for the help.
Dan
Stacy, it appears the issue was resolved: http://www.cruzetalk.com/forum/9-ch...off-do-i-need-go-dealer-reset.html#post161096Dan,
Did you have a chance to take your Cruze into your dealer to have this looked into? I would like you to keep me posted on this concern. If you have any questions please feel free to contact me anytime.
Thank you,
