2012, eco trim level, 1.4L turbo engine. Please help me to identify engine bay parts.
896 Views 7 Replies 3 Participants Last post by  Nikon1234
Hi.
My car is a 2012, eco trim level with 1.4L gasoline engine. Please help me to identify
item 1
item 2
item 3
item 4
item 1, 2 , 3 goes into item 4.
Thanks.
Motor vehicle Automotive fuel system Vehicle Gas Auto part
1 - 8 of 8 Posts
Items one, two, and four are hoses that come off of the westgate actuator solenoid. All of those hoses come with a new wastegate actuator solenoid.
Item three is the tube that runs from the bypass valve to the bypass valve solenoid. This comes as part of the PCV hose assembly.
thanks for enlightening.
I still do not make it.
could you get the parts diagram and explain a little more in detail?
like item one, what is the function of it? get some pressure to open the wastegate?
Dan
Dan
In order to explain further, I need to know what you already know about how turbochargers work and how they are controlled.
I watched the turbo on youtube, I only know the basic on turbo mechanism. Exhaust gas to turn on the high speed shaft, that shaft copress the intake air (passenger side) and send the intake air to the cooling stuff (enters at the passenger side and exit at the drive side), the air then enters engine at the driver side. the item 1 - item 4 are connected to the cylinder, that is the control unit for the wastegate (behind the heat shield), I understand that the wastegate is controled, to open when the turbo compression is too high, to relieve some pressure by opening the wastegate. My blind point is how this hose, connected to the cylinder (wastegate controller), control the wastegate, I guess that is a pressure controlled mechanism, and when the pressure is too high, it opens the wastegate, maybe someother hose to cooling as well.
Please enlighten me.
Thanks.
What happened to Nikon1234?
what do you mean?
I am only asking questions.
Nikon1234 asked the original question, and you (llinj2) responded as if you were Nikon1234. Do you have 2 usernames?
the link here should help explain turbo components if you select info.
oh. sorry.
llinj2 and Nikon1234 are both mine.
I am not familiar with forum, I do not know why my user name changes.
1 - 8 of 8 Posts
