1 - 3 of 3 Posts
Honestly Not Looking to Rant Have taken it into the dealership already " working as designed "
list of recent service
timing belt (69,000 miles
tensioner
accessory belt
valve cover
all seals replace (engine oil pan , oil filter housing , torque converter , main engine rear seal, trans seal ,etc)
new oil cap (just in case)
spark plus at 62,000 miles (just bought new factory plus from dealer)
evap canister
tcm fuse
ecm fuse
oil changed
current millage is 76,000
only when i idle the car the engine stumbles (rpm tach also jumps either up or down)
trans lurches forward and cuts power if im driving extra soft them use the accel a bit but then immediately go back to driving soft (gas saving )it will jerk /lurch you so hard forward
is it time for a trans fluid change AMSOIL??? anyone else with the engine stumble
mods to engine
k&n sri intake
rear muffler silencer delete
Does it have the same style PCV valve that the 1.4L has?
yes except the diaphram is on the left instead of the right side of the engine
i know mines is inside the cover so i cant look to see if that orange valve is there or not
1 - 3 of 3 Posts
