1 - 16 of 16 Posts
Hey there,
Been reading a lot of this forum and figured I'd get an opinion or two before I tear into my wife's car this weekend given my inexperience - I'm decently handy, but haven't gone this deep on an engine before.
The short version is I've got a loud engine ticking that sounds like this:
And a P0324 CEL code from my Bluetooth scan tool. ~65k miles on the engine, no warranty left. Seems like the power is lower too, my assumption was the CEL was throwing the engine into some kind of limp mode though.
Both of the symptoms (ticking and CEL) were intermittent, but have been more persistent lately. Here's what's been "diagnosed"/tried so far:
  • First shop to tried a fuel injector service to fix the problem, seemed to work at first but CEL came back
  • First shop suggested then said spark plugs "might help," but seemed like they were just guessing... now I get why
  • Dealer first said "bad gas," see if CEL goes off after a full tank
  • CEL stays on, 30 days later dealer says "major engine issue" and they could take it apart but "weren't sure if they could get it back together" (seriously?)
So here I am!
Based on some searching I believe it could be:
There also seems to be a bit of an oil leak somewhere, I see a small bit of it pooled around some areas, and my wife mentioned she smelled some burning once or twice a few months ago, and the last time I had the oil changed at the dealer (maybe a year ago?) the tech showed me oil residue on the pan while it was up on the lift. Level reads normal on the dipstick after ~5,000 after the last change, though, so doesn't seem like a major issue? Haven't noticed any drips under the car, ever.
Anyway, my plan is roughly this:
  • Ensure PCV check valve exists. If not, perform PCV fix.
  • Check for loose spark plugs, tighten if necessary.
  • Open valve cover and check for a loose timing chain guide. Torque to spec if loose.
  • See if I can see anything obvious once the valve cover's off. I doubt it, but I'll take pictures at least.
I have a few questions:
  • Should I replace the spark plugs while I've got everything open? Manual doesn't call for them until 100k but they're original, and it's what the original shop was going to do next.
  • If I take off the valve cover and put it back on, do I need to put on a new layer of sealant? If so, what's recommended?
  • Should I replace the valve cover while I'm removing it anyway, and potentially extend the time before I (or the next owner) have to deal with the PCV assuming it's intact? And perhaps help with the oil leak?
  • Anything else I should consider as a part of my plan?
It seems like this car is falling apart. Beyond the above, the thermostat had to be replaced 2 months ago, and a couple of weeks ago the horn started sounding funny and eventually blew a 15A fuse. Planning to replace that once I have a reason to drive by the auto parts store... but having all these parts fail at the same time is really making me question my sanity.
Thanks for your time.
Thanks for the pointer. Anything, in particular, make you think that might be the issue? Just asking because I haven't seen those be a common problem, but it's very possible I missed something.
Also took a few pics of where I saw what I think is oil pooled and maybe one possible spot it's leaking from...
IMG_20200203_222650.jpg IMG_20200203_222715.jpg IMG_20200203_222730.jpg IMG_20200203_222803.jpg
I've heard that sound before at the shop I work at. We changed the silnods due to a check engine light (don't remember the code)but changing them did make the noise go away. They are not to expensive and are easy to change
The video shows the purge valve ticking
ACDelco 55573017
This is a 10 minute R&R
I would pull the plugs and evaluate if they need changing or not
If the valve cover isn't "whistling" there is no need to change it
I would remove and reapply the sealant on the valve cover, the gasket will be ok to reuse
Keep us updated
ACDelco 55573017
Keep us updated
Holy moly, I think you're right that it's the purge valve making the higher-pitched noise. Stuck my ear by it and it's definitely coming from further back than the engine block.
Ordered the replacement and will keep you updated - worst case it goes back to Amazon with free returns.
Thanks again for the details and time.
The p0324
Check your charge pipes for oil. Oil will reduce the octane of the fuel and may cause knocking.
I installed a catch-can to alleviate this issue
Not a great start to this project... replaced the purge valve and the ticking continues. Went to verify the check valve in the PCV system and while doing so accidentally snapped the **** hose, so going to perform this mod: Corrugated PCV Hose Replacement/Upgrade
Going for spark plugs next...
P0324:
Potential causes for this code to set are:
Defective knock sensor/s
Internal engine malfunction
Ignition misfire/s
Contaminated or substandard fuel
Defective knock sensor control wiring and/or connectors
Bad PCM or a PCM programing error
Read more at: P0324 Knock Control System Error
This is my running click, tick and rattle list:
1. Could be just the injectors
2. Could be the plastic ECOTEC cover rattling
3. Check that the spark plugs are properly torqued -- 18ft-lbs (might as well re-gap them - .028 for a 1.4) and make sure the springs are not stuck/bent etc.
4. Could be a failing EVAP purge solenoid/valve or possibly a vacuum leak causing the purge valve to stay open
5. Could be a lifter tick - try seafoam or valvemedic
6. Could be the timing chain tensioner
7. Could be a sloppy timing chain
8. Could be piston slap/wrist pin failure
9. Pinging caused by low octane fuel
10. Could possibly be an improperly torqued bolt on the flywheel/torque converter (noise from the trans side)
11. Might be a bad wheel bearing
12. Possibly the knock Sensor going off or bad and it can be exacerbated by any of the above.
13. Maybe your AC compressor is going bad
Discussion Starter · #12 · (Edited)
Thanks for all the ideas.
I went ahead and changed the spark plugs this weekend while checking the tightness. Still sounds kinda like a diesel engine, unfortunately. Going to try running a few tanks of 93 and see if that changes anything.
For $5 I might give the oil conditioner a try next. I'm starting to doubt my timing chain guide theory because the ticking seems to be coming from the rear-right of the engine rather than the left-front-ish... so trans side I guess, but more towards the rear? Any bolts that typically come loose over there? The engine seems to be vibrating a decent amount at idle, to the point of visibly shaking the large plastic pipe on the top of the engine on that side.
Ran another scan and found I also have a P0325 code - not terribly informative, and my gut tells me the knock sensor is just doing its job rather than having an issue given the code and the ticking appeared at the same time.
edit: additional theory - loose rocker on the camshaft?
Many weeks later... but hope this can help someone else!
It turns out the "oil leak" with pooling I thought I saw was actually a coolant leak, shows how much I know. One water outlet valve replacement later and I think that's under control (did I mention this thing seems like it's falling apart yet?)
So back to the rest of the powertrain: I managed to cause a P304 (4th cylinder misfire) on my way to the auto parts store under WOT on the highway. Undeterred, I went ahead and bought some Valve Medic and dumped it into the crankcase with low expectations...
To my surprise it actually did seem to improve things over my drive home. It's still ticking louder than before this mess started, I think, but when I turned the car back on earlier (engine still hot) all the trouble codes were gone(!)
So I'm a Valve Medic believer for now... or maybe it was some combination of the shotgun approach of new plugs, premium gas, and a fuel cleaner treatment. If the codes come back I'm going to pull the coil pack off again and reinspect #4 more extensively... Stay tuned.
This is my UPDATED standing click, tick and rattle list (Thanks to many people including JBlackburn, Robby, BigLee and more) :
3. Check that the spark plugs are properly torqued - similar sound, mimics loose valves - Re-gap the plugs to .028, torque to 18 ft-lbs,no anti-seize with stock type plugs, inspect the boots and insure no rips / tears or holes, lightly coat the boots with silicone / dielectirc grease, make sure the resister springs are clean and not cocked in the boots.
These are the recommended plugs from the Hesitation Gone thread:
-BKR8EIX-2668 (iridium plugs), ~$25, expect ~10-15k regaps on these, ~40-50k overall life.
-BKR7E-4644 (nickel/copper plugs), ~$8, expect 15-25K out of these plugs, with a regap or two required at 5-8k intervals on stock tune.
4. Could be a failing EVAP purge solenoid/valve or possibly a vacuum leak causing the purge valve to stay open. You can find it right above your intake manifold.
Unplug the electrical connector to the purge solenoid while it's running, and see if the noise goes away. If it does, replace the purge solenoid assembly.
Many of these tend to get very noisy with age, and since it is duty cycled by the PCM it tends to sound very similar to valve-train noise. Part number is 5573017
5. Could be a lifter tick - how's the oil - possibly try seafoam or valvemedic
7. Could be a sloppy timing chain, one cause is a loose upper guide - tighten to 71in-lbs
8. Could be piston slap/wrist pin failure. Remember, piston slap would be noticeable also in neutral.
9. Pinging caused by low octane fuel, possibly try using 91 octane fuel for a few tanks.
11. Might be a bad wheel bearing, I personally had this issue.
12. Possibly the knock Sensor going off or bad and it can be exacerbated by any of the above. . The knock sensor is ALWAYS listening. The ECM is constantly adjusting spark/cam timing to run as efficiently as it can, and it should pick up on audible knock/pinging and adjust it before you even hear it.
14. Sometimes carbon on tops of pistons or valves can cause some knock. There are several "top engine cleaners" on the market to clean that off.
15. Fuel or brake lines vibrating
#PIC5853: Buzz Vibration Noise Floor Dash Area 1800-2200 Engine RPM - (Apr 22, 2013)
Subject:Buzz Vibration Noise Floor Dash Area 1800-2200 Engine RPM
Models:2013 Chevrolet Cruze
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern Some customers may comment of a buzz noise and or vibration in the dash or floor board areas, most noticeable at 1800-2200 engine rpm.
This condition may be caused by fuel line and/or brake line vibrations entering into the cabin area through the front of dash. Even though the fuel lines and/or brake lines are fully seated in their retainers, vibrations may still pass into the cabin area.
Recommendation/Instructions Use additional tape on the affected line(s) and/or add a small O-ring underneath the affected clip(s) to provide better isolation of the clip.
Further insure that the lines do not make any contact with the front of cowl that could further cause a noise or vibration.
Validate the repair by checking for noise or vibration at 1800-2200 engine RPM.
16. Missing air deflector fasteners
#PIC5874: Fluttering Rattling or Thumping Type Noise Above 45 MPH - (Jun 12, 2013)
Subject: Fluttering Rattling or Thumping Type Noise Above 45 MPH
Models: 2011 - 2014 Chevrolet Cruze
2012 -2014 Buick Verano
Condition/Concern
A customer may indicate there is a flutter or thumping type noise from the side or underneath the vehicle at speeds 45 mph and above.
Check the air deflectors mounted on either side under the vehicle. Make sure that all fasteners are in place and secure. Replace fasteners as needed.
If all fasteners are secure, it may be necessary to apply felt to the underbody above the the inside edge of each air deflector (between each fastener location) to eliminate this noise.
Different sound bytes to choose from:
Some of the associated error codes:
P0324: Potential causes for this code to set are:
Ignition misfire/s
Bad PCM or a
Discussion Starter · #15 · (Edited)
OK, so I'm not sure anyone is still following/interested in this saga but it's taken another exciting turn, and the only fun part is sharing the horror...
I was driving the car around, still loudly ticking, the other day and managed to cause a P301 under WOT again. Interestingly, a different cylinder from the earlier P304 code (#13). This time, the car started shuddering REALLY bad... managed to limp home, but was definitely not inspired.
Given the multi-cylinder problem with some more research - I replaced the coil pack, which initially didn't seem to do much, though the shudder didn't seem as bad.
Pulled the plugs from #1 and #4 (wasn't sure which was which) checked the gap and it was a little light - around .024 vs .028, so regapped and got them pretty close (around .030, maybe .029). Switched them with #2 and #3 respectively. Unfortunately, still no dice on the code, BUT the car actually started running a bit smoother. Ticking is mostly gone again, but I have a consistent P301 code now - no knock codes like P0324, and definitely not shuddering, it's drivable. At high RPMs near redline performance does seem to drop a lot, and that's when I get the CEL flashing most times.
Not sure I can trust this OBD reader, but the difference between Cyl 1 history and Cyl 2 current is strange...
289275
Any ideas? Thanks!
P.S. I did see a TSB that mentioned "Engine Stall or Stumble" 16-NA-015, related to the coil pack connector. My connector's tab actually did break off, but not sure it's worth replacing since it does seem to sit pretty tight in there.
Discussion Starter · #16 · (Edited)
Figured it'd be worth following up on this problem for someone to enjoy my misfortune. With COVID and all that, wasn't driving the car much but it was drivable. Unfortunately, that's no longer the case.
The other day driving home, there seemed to be a REALLY bad misfire that sent things off in the wrong direction. I had a P219A at one point, but that's gone away. Now I'm left with:
  • P0304, tons of misfires on Cylinder 4
  • P1101 (unplugged the MAF sensor at one point so could be nothing, or a symptom - air intake and MAF sensor seemed clean)
  • Flashing CEL at idle or while driving ("catalyst damaging misfire"), though not consistently at idle
  • Lots of shuddering/shaking of the car & engine. Higher RPMs / more throttle and it seems to go away?
Since I've already done spark plugs and ignition coil, and cylinder 4 looked a little... "wetter" (as in, the carbon buildup) when I pulled the plug - I went for fuel next. I checked the fuel injector on #4 and it looked damaged - but unclear if that was impacting anything:
293270
Here's what the other ones looked like for reference:
293271
But, swapping that injector over a cylinder to #3 didn't change anything - still tons of misfires on #4.
So, figure my next step is a compression test. And maybe pulling the valve cover off and inspecting the valvetrain, but not sure if I'd be smart enough to identify anything by looking at it. Appreciate any more ideas anyone has, or if any of these symptoms might indicate something right away...
EDIT: I did a compression + leakdown test and pulled the valve cover off. Next chapter revealed a lot more. Post here: Lifter + rocker replacement - worth it, right move, what am I missing? | Chevrolet Cruze Forums (cruzetalk.com)
1 - 16 of 16 Posts
