1 - 2 of 2 Posts
So my car generally speaking seems to fun fine besides some stutter at idle, and we've had it once or twice die when decelerating quickly off of the highway. I recently replaced the coolant reservoir because it had a big crack in the bottom but it is still slowly leaking coolant from somewhere. I bought some Stop Leak coolant sealant that I just put in yesterday.... I ordered a new Vapor Canister Purge Valve Solenoid for one of the codes that likely will fix that issue, and is cheap and easy. The underboost I'm going to have a friend do a boost leak test to see if there's a leak somewhere otherwise I may have to look at replacing turbo, but what about the other codes I hardly found any info on the P0650 for some reason it seems like no one seems to get that code, haha? Car has around 180k miles.
· Administrator
Potential causes for P0650 may include:
Burned out MIL bulb/LED
MIL wiring problem (short or open electrical condition)
Poor electrical connection at the bulb/cluster/PCM
Failed/faulty PCM
Read more at: P0650 Malfunction Indicator Lamp (MIL) Control Circuit
Check the connection at the water outlet. It has a tendency to disintegrate and crack.
Potential causes of a P0299 turbo underboost code include:
Intake (induction) air restriction or leak
Failed or damaged turbocharger (sticking, binding, etc.)
Faulty boost/charge pressure sensor
Read more at: P0299 Turbocharger/Supercharger A Underboost Condition
Potential causes for this code, P0299, to set are:
Defective O2 sensor(s)
Burnt, broken, or disconnected wiring and/or connectors
Defective catalytic converter
Engine exhaust leaks
Read more at: P015A O2 Sensor Delayed Response - Rich to Lean (Bank 1 Sensor 1)
Potential causes for this code, P015a,to set are:
The causes for this DTC, P2270, may include:
Exhaust leak near O2 sensor
Contaminated or failed HO2S2 (Sensor 2)
HO2S2 wiring/circuit problem
Loose installation of HO2S2
Fuel pressure incorrect
Faulty fuel injector
Engine coolant leak
Faulty purge solenoid valve
PCM has failed
Read more at: P2270 O2 Sensor Signal Biased/Stuck Lean Bank 1 Sensor 2
Potential causes of a P0496 EVAP code include:
Faulty purge or vent solenod/valve
Plugged EVAP canister
Failed EVAP / fuel pressure sensor
Faulty canister purge valve
Blocked vapor canister
Faulty vent solenoid
Read more at: P0496 EVAP Flow During A Non-Purge Condition
Causes for this engine code, P00B7, may include:
Low coolant
Stuck thermostat
Defective ECT sensor
Faulty radiator coolant temperature sensor
Shorted or open circuits or connectors
Bad PCM or PCM programming error
Read more at: P00B7 Engine Coolant Flow Low/Performance
1 - 2 of 2 Posts
