One of the more easily accessible items on the Cruze, the blower motor, had to remove mine because that squirrel cage blower wheel was hitting the shroud above it. Cure was simple, added spacers to the bottom of it.
Also could bench test it, draws 20 amperes at 14.5 volts. Just two terminals, reversing the polarity won't do any damage, just runs backwards. Could test yours off your battery with a couple of test clip leads.
Nothing worse than finding a blown fuse, have a short someplace that is not easy to find. Normally replace the fuse with like a 1057 light bulb with leads soldered to it and clips the same size as the fuse. It will light up until you find the short.
Can also be a firmware BCM problem, controls everything, those pushbuttons, just program the BCM, a PWM waveform fires a power MOSFET transistor to control the fan speed, even turn it on off. But if that transistor shorts out, fan will run all the time.
Good place to start is with the blower motor itself, to make sure it runs.
Ha, this is taking me back to the good old days when I could buy a brand new blower motor from my dealer for six bucks. But why should I spend that much, when I could buy new brushes and bushings for 45 cents? Was real easy to take it apart, and even put plenty of oil on those wicks. All this new stuff is throwaway.
If it is the blower motor, would only replace it with a genuine Delco, aftermarket is crap, 84 bucks at rockauto.com.
