1 - 4 of 4 Posts
Hi everyone
my Cruze L1.4 it’s been having a P1101 and P0172 code I haven’t been able to get rid of. It runs a little rough when the AC is on full blast idling. But it always has and with A/C off it runs perfect. I get a little bit of a fuel smell when driving sometimes. I have replace the following items within the last month.
map sensor
spark plugs
mass airflow sensor
intake manifold
throttlebody
upstream O2 sensor.
PCV hose
Purge valve
Looked at the valve cover for vacuum leaks. And all the air hoses for looseness. And I just don’t see anything. Here’s the freeze frame data. If you can help I would appreciate it. Hope I don’t have to take it into Chevrolet.
Gadget Communication Device Measuring instrument Gas Electronic device
Gadget Fluid Font Finger Display device
Gadget Gas Display device Font Electronic device
Gadget Display device Gas Measuring instrument Electronic device
Font Material property Gas Electronic device Display device
Gadget Material property Font Communication Device Gas
Font Material property Technology Electronic device Display device
Gadget Display device Font Measuring instrument Technology
· The Nuclear Option
So, P1101 is a mass airflow sensor out of range circuit code and P0172 is a rich condition code, which is verified by the -29% fuel trim.
The fuel smell is because you are running so rich.
Have you checked the MAF sensor circuit wiring to the ECM and the connections?
1 - 4 of 4 Posts
