Hi all i need your help. I have my car but know i have a huge issue. I changed my oil, with aftermarket parts, then this message start showing up. Beeping, so i stop the car. Oil was present, no wierd sounds on the motor.
So i came back, did the following thing:
1. replace the low oil pressure sensor
2. Replaced the low oil pressure Sensor connector
3. Put new oil filter (ac delco)
4. Put gages to check oil pressure, there is oil pressure..
but still the alarm and message shows... what else could it be? Anyone had this issue before?
all started when i changed oil and filter. I use synthetic oil full.
i dont know what to do, mechanic cant find the problem. Dealer want to replace the engine...i said no!!!Its not under warranty. 175k miles
