21 - 24 of 24 Posts
And it said to roll down drivers side window and roll back up! Anyone care to explain that one to me? An nope....ain't been drinking either! lol
That's normal after the battery has been disconnected. The Cruze has a feature where one bump if the switch will roll the window all the way down. That's not done with limit switches - the BCM remembers how long it takes. When you disconnect the battery, it loses that memory. So it has to be re-programmed. Kind of like how car radios used to lose station memories or time of day.
Reactions: obermd
what ecus are connected directly to power, could they be causing the batter "thru diodes leaking under certain conditions" cause the issue?
I've been having this same issue for the last 2 years and all tests are fine, battery has been replaced alt has been tested and deemed ok by Chevy. any help would be appreciated.
21 - 24 of 24 Posts
