I have a 2013 Cruze Lt. My water pump housing cracked which was leaking causing my car to run hot. I pulled to the side of the road noticed the problem replaced the housing but now my car wont crank at all. I replaced the battery which had a dead cell (took it to advanced to be tested), Tested the starter which is still good, replaced spark plugs and also texted fuel pump due to the smell of gas under the hood during attempts to crank the car... I need serious help
