The Cruze is one big computer. The commands run though the Body Control Computer which does the actual unlocking.Can't understand why the trunk release would be related
Did you ever find out whats wrong mine is doing the same thing 2 weeks can't figure outHate to kick a dead horse here but I have a 2016 setting in the drive way that is doing the exact same thing after installing an amp and disconnecting the harness in the driver kick panel. What ended up being the fix?
What ended up being the problem mine is doing the same thing please help 🙏 😭That is what I am afraid of, and the dealer is the only person that can diagnose the modules. Hopefully it isn't completely fried and they can reset or reprogram it. My main fear now is a $1k repair bill. The radio, lights, door locks, keyless entry, everything works it just goes blank when you try to start. The lights blink when you hit the trunk release on the fob but won't open nor does the button work.
I tried disconnecting the exhaust cam sensor, didn't start. Reconnected it and no change. Battery voltage is at 12.4. Charged it and it still doesn't start. Bypassed the ground cable and no change. It has to be one of the control modules.
Find anything out? The fix?That is what I am afraid of, and the dealer is the only person that can diagnose the modules. Hopefully it isn't completely fried and they can reset or reprogram it. My main fear now is a $1k repair bill. The radio, lights, door locks, keyless entry, everything works it just goes blank when you try to start. The lights blink when you hit the trunk release on the fob but won't open nor does the button work.
