2013 Cruze with about 71k miles, and a while ago it started misfiring on acceleration. I found a faulty spark plug and changed the set. I did see a little oil on the plugs but I do not know how old they were, I got the car at about 60k. Anyway, I put new plugs in and the misfire seemed to go away for a while. Now, the car will shutter when accelerating. It almost feels like a misfire or maybe a boost issue. I have checked what PCV things I could and cant see an issue. Maybe the air intake valve... note there was a small amount of oil in the intercooler charge line, I had an issue with both O2 sensors recently and they were replaced about 4k miles ago, and once I had an issue with a MAF sensor but that went away after I unplugged and replugged the sensor in. The car doesnt smoke and doesnt seem to burn oil, though I suspect the oil pan gasket is seeping, but thats unrelated. The air filter isnt all oily either.
Anyway, there are no CEL or codes, and the idle seems fine. But when I accelerate to like get on the highway, it will shudder. You can feel yourself go back and forth as it rapid fire shudders, and I cannot tell if thats it losing boost or missing. It does it at about the same RPMs every time too, about 3500. Messing with it, I could only get it to shudder if I was at about 3500 RPMs and also under moderate to heavy acceleration. Once you get to like 4000 RPM, it gets consistent again. Could it be the solenoid for the turbo at the back of the engine that controls the wastegate actuator? Is there a way to test if its a miss or a boost issue when it can only be observed under heavy load?
Maybe since it happens at a specific RPM range it has to do with the springs on the wastegate system or similar, where it flutters until the boost is high enough to keep it open or something, just wondering out loud.
This is my daily driver and I work 6 days a week so I have not much time to really dig into stuff and I dont want to take it to a shop if I dont have to, too expensive. Any advice on what to check or maybe if someone just knows whats going on?
