This trans has 22k miles on it. 2013 Cruze LUV 1.4T M32 LT
I first noted grinding when skip shifting 5th gear, so going from 4th gear to 6th gear. I try to wait a couple seconds to let the RPM's drop closer to where the gear should be, but it will still grind some amount.
This morning, I noted another way to grind 6th. It does it consistently every time, I'll explain:
1) Coast vehicle at speed
2) Clutch In
3) Shifter to Neutral
4) Clutch Out
5) Clutch In
6) Grind 6th Gear
Like I said, it will grind 6th every time here if you repeat that sequence 1-6. Is this "normal" as in it will be a waste of my time to deal with the stealer?
Edit: fixed MR5, thought it was the tranny code
2) Clutch In
4) Clutch Out
5) Clutch In
6) Grind 6th Gear
