Check the tire diameter, the tires can have a larger opening for the rims but the the overall same size with a thinner sidewall, I would imagine the wheel well is comparably the same opening in the two generations so if the put in in the 2013, same boot pattern and wheel well opening, then you should be fine, just compare the tire size, mine are p225/45 r18
Sent from my iPad using Tapatalk
