As you can see, the gasket isn't sealing. Replace the gasket and Inspect the new housing for cracks while you have it off.Last week I noticed that my 2014 1.4L was leaking coolant from what appeared to be the thermostat housing (ended up being cracked). This solved the majority of the problem but there is still a slight leak. See the imagine below, It is now leaking right between the water pump and thermostat housing. Has anyone experienced this before with a new thermostat housing? Could the brand new thermostat housing be bad or is that gasket maybe not sitting in there correctly and not sealing to the water pump? It seems to be a pretty steady seep out of there. I made sure that the bolt was nice and tight. Any ideas?
View attachment 289847 View attachment 289848
Welcome to the forum.
