That is so strange - those don't typically work themselves loose...
God I hate sliding calipers.
Further cementing my hatred for sliding calipers. Thank god my brother's Regal has Brembos up front, though he still has slidings out back (though at least with ventilated rotors).Confirmed today that my lower slide is seized on both rears. 100 bucks for a pair of brackets and kits from the dealer, re-machine the rotors and I'll be on my way with the same regimen as you from now on @boraz. Pads have a half mm or less of taper wear, I can live with that.
Sent from my SM-G781V using Tapatalk
I've become so familiar with the sound that I can tell you just from listening, without even inspecting. The set I put on to replace the originals were the Moog steel end links instead of the factory plastic. It could be that the plastic end links are more durable because the plastic flexes to take stress off the joints on the ends. The right side has now gone through 2 Detroit Axle steel end links after the Moog. Since the right keeps breaking while the Moog on the left has almost 150k on it, it could just be a function of dealing with the crumbling right side of most West Michigan roads. I've thought about going back to the plastic, but I like the performance of the steel better. Once I use up this last steel end link I have sitting on the shelf, I'll probably go back to plastic next time it breaks, since I'll be passing it on to daughter #2 shortly after that point and the durability will be a higher priority than the performance.I can't say I've noticed any noises that I would associate with bad swaybar end links - ours are still original at 136k miles
It's a mild clunk going over bumps. The first time I thought it was a spring insulator or strut mount, before I finally tracked it down.What is the sound? I’ve got steel end links and now have a squeak on the right side. Thought it was from a bushing but after reading your post now not sure maybe the R end link is going out after 30k miles.
Whiteline makes adjustable end links for our cars which I may install next time.
