Need some help wondering if somebody has some electrical diagrams for the ac system for a 2014 2.0. The ac pump clutch engages and disengages properly with the button. Right now the condenser fan isn’t kicking on while the ac is engaged. I also checked pressures and the low side is reading high (85) and high side is reading low (120ish) checked fuses and all 4 relays under hood. The ac worked perfect before i swapped the engine in this car and i never did break the system i just removed compressor and wired it up in engine bay and hooked it back up on new engine. I also show b393b-04 on the hvac control module. Thanks In advance
