1 - 4 of 4 Posts
I have a 2014 Cruze ls I am having this issue where going from 2nd to 1st gear at a stop results in a hard downshift. Also I am having jerky acceleration. The biggest question I have is when I’m at a stop w/ the ac on the rpms go down to 1000 for about 5seconds then down to 800 so it hangs for a little bit idk if that is normal or what could be causing that. Any advice would be great.
Thanks
Is this an automatic? Mileage on the car? Transmission fluid ever been changed?
RPM behavior sounds normal.
Yeah automatic 55000 on it and fluid was changed at 45000
I would start with having the fluid level checked. Warmed up fully, trans temp at 180+, idling in park, pull out level plug on left. Fluid should trickle out in a steady stream.
Leaking trans cooler lines are pretty common on GM vehicles, so that's a possibility too.
1 - 4 of 4 Posts
