Got a 2014 Cruze LT that's making a weird ticking noise. Went to get it scanned and these codes came up: P0171, P0106, and P1101. Anyone know what the problem might be? I was told fuel injectors but not 100% sure. Called dealership but apparently I'm not under warranty anymore. Any help would be greatly appreciated!
P0171 is almost always the PCV valve/camshaft cover and unless you're over 100,000 miles it's covered under the power train warranty. P0106 is a manifold sensor error. The manifold is also a power train item. P1101 is a mass airflow sensor alarm. How many miles do you have on your Cruze? I suspect you have a power train warranty item, but a good dealership will warn you up front that you may have a diagnostic charge if not covered under power train.
