Take it to the dealer. I'm sure at least something is covered under powertrain warranty.
Welcome to the community here, you have came to the right place for help! These are a great group of guys/gals always willing help determine the cause of your issues. The code you mentioned in one of your previous post, I actually received that engine code yesterday & took to the dealership today to find out I had a bad catalytic converter, but yours being a 2014 seems really odd to have a bad catalytic converter at age. But possible due to a few points of running rich, etc.Check engine light is P0420 (Catalyst System Efficiency Below Threshold (Bank1))
Normal. The cruze's charging system is variable to allow for better mpg. What you're seeing is a fully charged battery which tells the computer to kick off the alternator to get less drag on the engine. In the Cruze, a properly working charging system and full capacity battery will result in frequently fluctuating charging voltages. It's when you notice it constantly high 14s and low 15s that you know you're going to have a battery problem soon.Only thing i have noticed is before the Volts were around 14.4-14.5 via the dash. Now it fluctuates from high 11s to high 12s?
Thanks again for all of the help
I'm looking for bad catalytic converter 2014 cruze talk. Car has 80k, check engine light came on again. Had it in for a powertrain repair covered under power train warranty a few months back. It had been losing vacuum so they repaired a cracked cover which I'll get them to take me through step by step tomorrow. Now check engine light on again and they say it needs $750 catalytic converter replacement NOT covered under warranty. Seems to me having owned cars for 39 years with about 100 years of car ownership having never heard of replacing a catalytic converter that something caused the failure. Also, that $1800 bumper to bumper warranty good for 100k miles should cover it. Am trying to rule out that Chevy has an issue with those cat converters on the Chevy Cruze. My initial assessment is that the issue they repaired a few months ago has caused early failure plugging the catalytic converter. Even if that weren't the cause, it isn't a wearing part that fails in 3 years or I would have heard of it before having 100+ years of owning cars, so bumper to bumper $1800 warranty will cover it or else I'll never buy another Chevy. My son dropped the car off, so maybe they are just taking advantage of a 28 year old down at the dealership. He hasn't worked on cars much. I have, and have never had to replace a catalytic converter. lol who ever heard of such on a 3 yr old car?Welcome to the community here, you have came to the right place for help! These are a great group of guys/gals always willing help determine the cause of your issues. The code you mentioned in one of your previous post, I actually received that engine code yesterday & took to the dealership today to find out I had a bad catalytic converter, but yours being a 2014 seems really odd to have a bad catalytic converter at age. But possible due to a few points of running rich, etc.
Not just the Cruze from a part expense standpoint.Thanks, Rob. That is very helpful. It runs fine just slight loss of power, so guess things could be worse. Since it is past the 80k emissions warranty, would it hurt to switch that out for a kit? Do you know if that voids any other warranty? Eldest suggested that today.
I've learned since yesterday afternoon when I received the sad news that very expensive parts regularly fail on the cruze. We are discussing today that we need to get rid of it by 100,000 miles due to all the issues.
