I just recently bought a 2015 Cruze LT RS and from what I've looked up it looks like the OEM suspension parts have a different part number than that of the 14 and earlier models. Has anyone had a chance to see if the coilovers from an earlier model will fit on a 15
I just successfully installed 2011-2014 B&G springs (as labeled by the mfg) on my 2015. Everything is exactly the same as older models, suspension-wise. All bolts were in the same locations and same sizes. The coil overs should have zero fitment issues.
From 2012 to 2015 its all the same, so you can install whatever kit u want.
Btw, depending on where u live and what u want to do with the car, i would think alot b4 installing Coil-overs and whatever u decide, keep your stock suspension somewhere in storage, you never know in the futur what u will decide. (I know from experience)
Reactions: Rockhead
Discussion Starter #4
On my cobalt I just installed lowering springs and got rid of the factory but I feel the coilovers will get me a better ride feel since I can adjust it. Also helps that I can make them a lot lower than just springs
Coil-overs are always a better option, but they cost more and when they break, its a pain to repair/replace them, thats why keeping your stock suspension in storage is a must.
I love coil overs but only if you take the time to dial them in. if you go by a generic reference and don't take the time to test drive,tune, repeat then you will not get all the benefits from them. here in florida you can safely lower. I wish Tien made coil overs for the cruze. they are some of the best around
