1 - 11 of 11 Posts
Interesting.
The 2015 GM Car VIN document (above) gives us a peek at what's coming in 2015 Cruze vehicles; the same as before:
• Engine Code B = (LUV) 1.4L, MFI, DOHC, Turbo, VVT, Alum, E85 Max
• Engine Code G = (LWE) 1.8L, MFI, DOHC, VVT, 103kW
• Engine Code H = (LUW) 1.8L, MFI, DOHC, 103kW, E85 Max
• Engine Code Z = (LUZ) 2.0L, Diesel, CRI, VGT (turbo)
There are no Fastback or Stationwagon models in 2015, just the same notchback (Body Type 5).
CORRECTION: sorry, the K and V engines are actually for the Verano (darn)!
• Engine Code K = (LEA) 2.4L, SIDI, DOHC, Alum, E85 Max
• Engine Code V = (LHU) 2.0L, SIDI, DOHC, Turbo, Alum, E85 Max
Text Font Line Parallel Diagram
Looks to me like it's still the same engines.
Yeah, I see the same.
Wasn't the new Cruze supposed to be a 2016 production year anyway?
Yes after the two re designs.
Sent From My Galaxy Note 3.
Which is bigger than my hand.
On page 5, look under the 'Book Code(s)' column for Vehicle Line Code "P" (P = Cruze; J = Sonic) engine listings.
Ah, but the Verano is also listed as a "P" platform, with different series numbers. (Cruze - PA, PB, PC, PD...) (Verano - PN, PP, PR, PS...etc)
Which makes sense because those are the engines the Verano already uses.
Ah shucks, I stand (sit?) corrected!
Didn't notice that BOTH Cruze and Verano had the P code...however that DOES (ha,ha) actually prove my contention that the Verano is basically just a "re-badged" version of the Cruze.
Little bit of the "old" GM still at work ;)
Epic Beard Man
Reading this stuff turns me on waaaaaaaaayyyyyyyyyyyyy too much.
1 - 11 of 11 Posts
