Replaced
-pcv pipe
-valve cover/pcv valve
Car does fine while moving. Also seems fine until it warms up. Setting at idle at a traffic signal the RPM's will begin to fluctuate then the engine will stall. Restart is normal. I can footbrake and hold the throttle to about 1200 rpm and it will not stall. It throws multiple codes. I will get an update on the codes. Any ideas? Where or is there an IAC sensor?
-pcv pipe
