Hi Everyone,
I have a 2016 Cruze with around 100,000 KM on it and I just started getting a squeaking type noise when coasting. The problem only occurs once I have accelerated to speed (around 40 to 50 km/hr) and then let off the gas. As soon as I let off the gas I hear this squeaking sound. If I press back on the gas the noise either goes away or I can no longer hear it do to the noise of the engine. If I press on the breaks the noise is still there.
The noise is cyclic with wheel speed so as I coast down to a stop or slowly apply the breaks the squeaking noise slows down. It also appears to have a two hits per revolution: do-do; do-do; do-do; At first I thought it was a typical wheel bearing problem since it has all the usual symptoms but rather then a grinding or wow - wow - wow sound it sounds more like rubber squeaking. Almost like a kids squeak toy. So I was thinking I could rule out wheel bearing. Since it is not a grinding type sound (metal to metal contact) I want to rule out rocks stuck between rotor and backing plate. Pads are also in good shape so I find it hard to believe it would be the wear indicator on the brake pads. There is some rust forming on the edge of the front rotors so I know this needs to get fixed but again I think this would be a grinding type noise.
The sound to me sounds like a squeaking control arm bushing or some type of suspension related problem but since the noise is cyclic I find it hard to be suspension related. I have shaken all 4 corners of the car and I do not hear any noise when the car bounces.
The last thing I noticed is that the rear drum brakes have a tight section. If I put the car on the lift and rotate both rear tires (one at a time) for about 270 degrees of rotation the tire spins without any resistance and then for the last 90 degrees (approximate) the wheel becomes harder to turn. It does not lock up but it does take some effort to turn past this section. From this I would guess my rear drum brakes need to be adjusted but I do not see this being the cause of the noise.
Anyways I thought I would post my problem here to see if anyone else has heard this type of noise before and could point me in the right direction.
Thanks,
Bob
Thanks,
Bob
