1 - 4 of 4 Posts
Hi all,
So my 2016 cruze base had a stabi track light come on and service said a mouse chewed through it so no warrenty... Ordered the part that day and got it a week later. Went to replace it and it's the female end ( side that goes into the harness) cant find it anywhere to buy so I decided to look here to see if anyone has any solutions or had this problem.
284591
It might be Part # 13586115......Acdelco PT2831 ....$50-70 ..Can't tell from your picture.
Or go to your local dealership?
284592
If you have a "pull a part" wrecking yard near you they may have a Cruze you can cut the connector off of for cheap.
Standard practice is to replace the entire harness. However big and expensive that may be.
Don’t bother searching for the connector. The only other options are to cut both the sensor and harness and install a new different connector, splice them together, or splice the connector from a donor harness. But at that point why not take the whole harness?
1 - 4 of 4 Posts
