After searching thru about a dozen pages with the search bar, I give up.
I need the pinout diagram for the bcm on my 17 base model 6 speed.
After the install of a rostra cruise control module (how ironic that a cruze doesn't have cruise) the left rear turn signal does not flash and on dash it goes into hyper flash. Bulb is fine and if I uninstall the cruise module (just unplugging the 4 connectors that go to the module) the bulb still doesn't flash and it goes into reduced engine power due to codes pertaining to the throttle pedal assem (the cruise module has an in line connector that piggybacks from the wiring from the pedal)
According to the instructions via rostra, I only had to tap into 2 wires in the car. The red wire from the ignition switch, and the #11 position grey/yellow wire in the black connector at the bcm. I'd like to get a wiring diagram for the bcm so I can check what wire that is and if maybe somehow I pulled a wire out accidentally.
I called rostra first but they're closed on Sunday of course.
