In the gas doorWhere do you fill the DEF if there's a spare? I don't think I saw a cap...
Sent from my ASUS_Z01BDC using Tapatalk
Y'all mean in the diesel door.In the gas door
It was on verano so could be done.still waiting for someone to retrofit heated steering wheel onto gen1
Push to open on the outside.is fuel door same as gen1 pop open from outside or locked from inside?
I agree. They look too small for the car. Will be OK at tire-buying time because 17s cost more. I'm already thinking about upgrading to aftermarket 17s. I've never done aftermarket wheels before, but these need help. Black wheels on my Summit White would look sharp.Also the 16" wheels look miserly.
It has a very low-pitched drone on the highway. I like it. Almost can't tell it's a diesel from ambient sound, but the low purr is definitely there.Worth noting, while my phone might pick up the intricacies of engine noise, that little ******* is quiet. hahaha. whisper diesel is not misleading.
It's worth mentioning the what sounds like the turbo whistle from 0-10 MPH.It has a very low-pitched drone on the highway. I like it. Almost can't tell it's a diesel from ambient sound, but the low purr is definitely there.
True enough about the ride with the 16s. It's less planted in curves than I'm used to coming from other cars this size, but I spend the majority of my time on the highway, so I'm very pleased with the ride.
Speed limit exceeded warning! Arrgh.. could do without that!And a little pull.
