@neile300c was this you?
Welcome Aboard!:welcome:this has happened numerous times to my 2017 LT.... what could this be and will it leave me stranded?? does the front cupholder trick always work??
When I had it, the cupholder trick did not work all the time. First thing I would do is change the battery on the fob. If it continues to happen, bring it to the dealer to perform the TSB. I haven't had any issues since they did minethis has happened numerous times to my 2017 LT.... what could this be and will it leave me stranded?? does the front cupholder trick always work??
For the benefit of those who don't have the app, there is a manual key inside the remote that you can use to to get into the car. The keyhole is hidden by a plastic cover on the handle.I've had this happen to me twice now on my 2017 Cruze. I now know to put the key fob in the first cup holder and it will start. Thank God for the Chevy app so you can at least get in the vehicle. I don't know what happened or why the first time it did this. Today, I wonder if there was some interference from another key fob I had in that cup holder. I'll check later to see if it does it again.
Thanks to this thread I was able to tell the service advisor there was a tbs for this fob problem that happened to my 2017 lt with 7,000 miles on it this morning! It was the receiver in the car they replaced to fix it! Kinda threw me when the message popped up basically saying put foot on brake, put remote near transponder to turn off the engine with push button.When I had it, the cupholder trick did not work all the time. First thing I would do is change the battery on the fob. If it continues to happen, bring it to the dealer to perform the TSB. I haven't had any issues since they did minethis has happened numerous times to my 2017 LT.... what could this be and will it leave me stranded?? does the front cupholder trick always work??
The cupholder trick doesnt always work. especially if the battery in the keyfob is low.this has happened numerous times to my 2017 LT.... what could this be and will it leave me stranded?? does the front cupholder trick always work??
Does it require the use of OnStar??? It's too expensive for me to use OnStar.If you have a smartphone either go to the apple store or play store and type in myChevrolet and download it....you can use your onstar subscrption to sign in to the app... from there you will see the fob controls.... you can unlock/lock your doors, start your car if you have remote start and sound the horn and flash the lights too... its kinda cool
Well the FOB is recognised, it still locks and unlocks my doors. It still allows me to start my car via the push button when i'm in the drivers seat.I don't think so. But, it is like remote start. If the car doesn't recognize the fob, it still won't go anywhere.
Normal. Per the user manual, remote start won't work if there's a CEL condition. Fix the CEL and I'll bet the report start comes back.ON another note I am having similar issues with my remote start. It stopped working then the engine light came on.
